swing arm bearing? how tight?
Old May 5, 2013 | 01:59 PM
Bob Hosie's Avatar
Default swing arm bearing? how tight?
Hi! I finally got my races out of my swing arm.(lol) Iam now attempting to put my new bearing back in. I was wondering, the bearing came loose inside the race. when i tap the races and bearings back into place, do the bearing remain loose or are they suppose to be tight inside the race, so as not to be able to come out? Or does this all this tighten up when i put the sing arm back on the quad and put the bolts back in? Any advice would be appreciated as always.....thanks..bob I have a 2004 vtwin 700 prairie 4x4
Old May 7, 2013 | 09:42 AM
PRAIRIEOUTLAW's Avatar
The bearings will come out of that outter race. The race itself should fit tight inside the grove that they fit into or they are the wrong bearings, but the outter race and bearings are able to be separated without any problems.
When you get it all back together it will stay in place.
Good luck.... This is the hardest part of the job.... Getting it all put back together... LOL
Look at this pic... http://www.cyclepedia.com/wp-content...VF650_1271.jpg
Is this what your talking about? If so, then perfectly fine.
The outter race is already inside the swingarm on this pic by the way.
Old May 7, 2013 | 03:39 PM
Bob Hosie's Avatar
Default Thank You!
Thank You! All you guys on here are great! I'm new to a lot of this, and i depend on your information! Thanks again.....bob
Old May 8, 2013 | 07:53 AM
No problem... Been there, done that, and bought the t-shirt, but used it as an oil rag already... LOL!
Like yourself, I use forums to figure out questions when I'm not t sure on something new, so just trying to repay the favor...
Hope you have good luck with your repair.
exmotocrosser
Sep 13, 2019 06:12 AM
jbrewster94
Sep 23, 2015 04:16 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
