kazuma 90 falcon charging issues,
Old May 6, 2013 | 08:11 PM
scortycat's Avatar
Default kazuma 90 falcon charging issues,
so my kids 90 falcon wont charge battery im sticking right at 12.3 at idle , i replaced voltage regulator , stator and cdi box, and i cut the whole wire harness apart looking for broken wire everything seems ok. i cut a couple solder splices out and reconnected with buttconectors and heat shrunk everything back up, thinking maybe someone at the factory got sloppy and didnt get a good connection idk. now my real question i guess is with this bike is , with the battery hooked up not running with the key on shouldnt i have 12.3 at the voltage reg (not running) at least at the red or yellow wire ? if someone has a better idea on trouble shooting this bike let me know. im sure this has been an issue with other falcons any ideas guys ? thanks
Old May 7, 2013 | 06:38 AM
Jaster94's Avatar
what was the battery voltage before you started the quad? what was the voltage with it revved up? have you checked the stator output at idle and with RPMs up? if so, what is it putting out before the battery as opposed to at the battery?
Old May 7, 2013 | 07:19 AM
scortycat's Avatar
12.3 not running, when running 12.2. theres 36 volts off the stator , i have no power at voltage regulator ?........
Old May 7, 2013 | 05:49 PM
scortycat's Avatar
got her figured out idk what i did but its charging 14.1 at idle. im sure it was the ground wires solder cluster eeffffed together.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
rjacree
1) Engine problems..
Aug 3, 2015 10:21 AM
200es
Jul 19, 2015 04:50 PM
