700 sportsman header bolt torque?
Old May 8, 2013 | 07:13 PM
dakbee's Avatar
Default 700 sportsman header bolt torque?
im working on one for a friend and need to know what they need torqued to. he says they keep coming loose
Old May 9, 2013 | 02:10 AM
Common problem on these to loosen from vibration.Make sure the gasket is in good shape. Loctite good then torque these 8mm bolts to 216 inch pounds(18 foot pounds)
Old May 9, 2013 | 02:20 AM
dakbee's Avatar
would loctite be much use with the high heat? i found out tonight that 2 holes are almost completely stripped out, there was 1 bolt missing, 2 metrics and 1 standard bolt in. standard is correct, right?
Old May 9, 2013 | 02:30 AM
Problem is from the factory no loctite was used! These are 8mm allen head bolts. If someone has installed a standard bolt,then quite possibly you need to retap and helicoil,especially if threads are damaged.http://www.ebay.com/itm/exhaust-gask...-/300776281873
Old May 9, 2013 | 10:15 AM
dakbee's Avatar
is there any reason to use the allen head bolts instead of hex?
Old May 9, 2013 | 10:25 AM
Doesn't really matter as long as you can get a wrench on the two center ones.Clearance between the exaust tubes is the main thing..
carolinabomb
Jul 26, 2015 08:40 AM
skeets44
Jul 17, 2015 01:04 PM
Unzzy66
Jul 11, 2015 10:01 PM
Shifts
Jul 3, 2015 07:59 AM
