Scrambler 400 won't run
Old May 12, 2013 | 01:44 PM
Connor Schuster's Avatar
Default Scrambler 400 won't run
I've got a 2001 polaris scrambler 400 fresh top and bottom end and now it won't stay running the motor prolly has about 7hrs on the rebuild but today I drive threw some water foot board deep and it was fine but then going home I drove back threw it and on the way out of the hole it would barely move and not even rev up and now it when start at all please help thanks in advance
Old May 12, 2013 | 03:16 PM
Probably a combination of water in the clutches and splashed water in the electronics. Just pop the front panel,use an air blower to blow out any water. I'd use some dielectric grease(if you have it) on all connections and pull the plug cap to see if any water there. Stators get a lot of water through the recoil housing and the rope itself too. Some silicone the rope handle to help keep water out. There's a 14mm drain plug at the bottom of the recoil housing that you can remove to see if any water's in it.A little WD40 works wonders with the spray tube in the stator area on water dissipation. Clutches will usually dry themselves out if you leave it in neutral under a high idle for a few minutes then drive slowly until clutches are completely dry and not slipping.
Old May 12, 2013 | 06:31 PM
It was the spark plug the gap was .050 and it ran fine and just folled the plug
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
