TRX465
Old Mar 26, 2001 | 12:21 AM
TrX465's Avatar
i got a 465kit with a lightned flywheel, 6 degree advanced timing, titanium valves ,Custom race cam, 3-way valve job, port polished, hot rod (rod),customed made cam chain, Lrd big bore exhaust, trued and welded ,had the crank shaved down , alcohol for my 39 fcr carb ,i got an 8 inch swing arm, chromed frame, polished head,case custom design paint on plastic
((((((AS THE T-REX EATS THE RAPTOR))))))
Old Mar 26, 2001 | 08:56 AM
garyc660R's Avatar
Nice engine mods. If you don't mind...how much did the kit set you back and how does it compare with a stock Raptor on low-mid and top?
Old Mar 26, 2001 | 10:50 AM
THEXOTIC1's Avatar
Sounds expensive. I had a 300ex big bore to a 405. these motors are time bombs. sure they ar great but be prepared to take them apart alot even thought they run properly. we had oil leak out of the top head. so we pulled the motor. We found more problems than the oil leaking. well good luck with the motor. No more big bores for me.
Old Mar 26, 2001 | 12:03 PM
TrX465's Avatar
I did all the work my self im sponsered by ysa motorsports they give me 40% off then i put it all together my self for everything it cost $500
not bad for a 16 year old
Old Mar 26, 2001 | 12:06 PM
TrX465's Avatar
this is just my trx465ex i have a banshee with snow mobile heads on it with a 10mm stroke,alcohol,drag pipes , its supposed to be a 580
Old Mar 26, 2001 | 04:05 PM
pudjumper's Avatar
That is very cheap. I'd give you $250 for a fcr39. (314) 752-6352.
Jay
Old Mar 27, 2001 | 12:28 AM
Trx440's Avatar
Where is YSA? What lines do they carry? Do they sponser you for sand drags?
Old Mar 27, 2001 | 12:37 AM
max400ex's Avatar
wow sounds awesome!! and especially for being 16... I hope I'm at the point you are when I turn 16! That is awesome that u did all that your self! and a great deal too!
Old Mar 27, 2001 | 09:49 AM
Blodg500RX's Avatar
Sorry TRX465, but there is no way that all those mods can be done for $500 even with 40% off and doing the work yourself. The FCR carb alone retails for at least $450 so 40% off the cost is $270. So the rest of the mods were done for only $230? Since you did the work yourself why don't you list the cost of each component so we can understand how it was so cheap. I will start the list just so you don't forget anything:
FCR carb - $
Big bore piston - $
Machine cylinder for big bore sleeve - $
Big bore sleeve - $
Hone sleeve - $
Hot Rod - $
Lighten flywheel - $
3-angle valve job - $
Titanium valves - $
Port & polish head - $
Custom cam - $
Cam springs and retainers - $
Cam chain - $
Weld and true crank - $
LRD exhaust - $
Gasket set - $
HD Clutch - $ (stock clutch would not hold up)
+8" swingarm - $
Regardless of the cost, if you have all these mods that thing should be extremely fast. I have two 492cc big bore motors and have never had a problem with reliability as thexotic mentioned.
Old Mar 27, 2001 | 01:11 PM
TrX465's Avatar
See my dad owns a machine shop, He knows the people at krank works , half the stuff i have i had done for free ... i know all the people i ride with them or my dad knows them.... and dont forget im a mommas boy...
16 years old
