sortsman 400HO
Old May 26, 2013 | 11:49 AM
randymack's Avatar
Banned
Default sortsman 400HO
My 2008 sportsman 400HO throttles and accelerates normally up until its at maximum. when i go over 90% it stutters/stammers and starts to die. The first time this happened i was heading down a hill giving it full throttle and when i stopped it died. wouldn't restart. took off the side panel and i saw what i believe to be the carbereuter dripping fuel. I noticed also my filter and charger were dirty so i took them off,cleaned them and it eventually started. But it's not quite the same and doesnt reach full speed. I then noticed the gas tank gauge now spins around and i can see the floater at the top of the tank.
any idea what happened here?
Old May 26, 2013 | 12:58 PM
If it's just the center metal part that the float ramps up,it could be like some I've found that just came out of place. If it's needs replacement,dealer seems to be the only option as all aftermarket places don't seem have it. Body, Fuel Tank A08 Lh46 Aq/Ax/Az Polaris Sportsman 400 HO 4x4 (A08LH46AQ/AX/AZ) 2008 OEM Parts - Cheap Cycle Parts
On the carb leaking,might be time to install a new carb kit. http://www.motosport.com/utility/200...TOR-REPAIR-KIT
panicmanic
Sep 28, 2015 12:59 PM
WilliamBos
Sep 22, 2015 04:07 PM
WilliamBos
Sep 15, 2013 04:46 PM
Muddingman12
Dec 18, 2012 07:40 PM
jokout
May 13, 2008 07:10 AM
