need help with parking brake block off
Old Mar 26, 2001 | 03:25 PM
hrc200x's Avatar
I bought a Lonestar parking brake block off from Dennis Kirk and put it on my 350x, but I lost rear brakes at the same time. the stock thing I took off had a o ring and this new thing doesn't. Do I need to make a gasket or what? Please help
What have you guys done with yours?
Old Mar 26, 2001 | 04:49 PM
ModdedX's Avatar
I got mine and bolted it up, no problems on my X...
i got a Nac's Plates.. Cant remember if there was an o-ring or not...
Try some permatex gasket goop on it and see if it works.
Old Mar 26, 2001 | 07:57 PM
54warrior's Avatar
it should just bolt right on, there is no need for a gasket.
Old Mar 26, 2001 | 08:56 PM
MX265X's Avatar
just put the block off on and the add brake fluid and then bleed then and you should be grinnin!
Old Mar 27, 2001 | 12:05 PM
hrc200x's Avatar
On a different forum they said there might be a inner o ring that is bad and letting brake fluid come through. FOr this one I put it on and lost brakes so I filled the resivour up and bleed them but as soon as I pumped the brakes it just leeked out the plate I put on.
1ArmBandit
Sep 8, 2015 08:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
