Wanted DS650 Piston Rings
Old Jun 28, 2013 | 06:46 PM
DaSandBomb's Avatar
Unhappy Wanted DS650 Piston Rings
I'm in need of a set (mainly the oil seal) Piston Rings stock size 100mm, I can't believe that I cracked a ring putting her back together. I have an 04'Baja X that I'm trying to resurrect and was just about done. If need be I may take a descent piston and ring set since you may not want to part with just the rings, used is ok if clean and undamaged.
Any help would be great, throw me a price.
Old Jul 19, 2013 | 10:55 PM
justme23005's Avatar
I have a piston and rings that have less that 30 hours on them. Are you still looking for one?
Old Jul 20, 2013 | 10:03 AM
DaSandBomb's Avatar
Thank you for the response, I found a piston and picked up new set of rings already, just fired her up last night. Going to do a few heat cycles and then recheck the Valve Clearance/shim setting before putting everything back together.
southbayman
Jul 24, 2015 09:30 AM
xbin87116
Jul 13, 2015 02:10 PM
clsharky
Jul 13, 2015 02:07 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
