Wanted DS650 Piston Rings
I'm in need of a set (mainly the oil seal) Piston Rings stock size 100mm, I can't believe that I cracked a ring putting her back together. I have an 04'Baja X that I'm trying to resurrect and was just about done. If need be I may take a descent piston and ring set since you may not want to part with just the rings, used is ok if clean and undamaged.
Any help would be great, throw me a price.
Thank you for the response, I found a piston and picked up new set of rings already, just fired her up last night. Going to do a few heat cycles and then recheck the Valve Clearance/shim setting before putting everything back together.
Mojave250A
Jul 11, 2015 10:38 AM
