Rear bearings and seals on Foreman. Help!
Old Mar 26, 2001 | 08:51 PM
josh1's Avatar
My left rear bearing the one on the opposite side of the brake drum is pretty much gone! I heard some scraping and screeching from the back and when I investigated the seals and bearing were pretty much gone! Can I install this my self? Is it hard? Do I have to take the shaft out? HELP! THANKS!
Old Mar 26, 2001 | 09:51 PM
plp2's Avatar
you can do it your self takes about 15 minutes changed one on a friend of mines 450 if ya run in a lot of water might be wise to fill tube that the axel runs through full of grease don,t have to pull axel just pull tire remove axel nut pull hub then ya can see seal bearing is in behind also a spacer be shure to put spacer back in hope this helps
Old Mar 31, 2001 | 03:03 PM
muzzy3's Avatar
It's very easy. Mine did the same thing this winter.
STLyamwar
Jul 25, 2020 04:44 AM
robert301972robert
Aug 30, 2015 11:34 AM
coolguy420
Jul 28, 2015 01:54 AM
Peter_
Jul 18, 2015 07:06 AM
clsharky
Jul 13, 2015 02:07 PM
