DS 650 Backfiring bad.
Old Jul 16, 2013 | 04:08 PM
Ajkd4's Avatar
Default DS 650 Backfiring bad.
I just bought a 2002 Baja 650 with a slip on pipe. I knew it was not running right when I bought it. It starts perfect but as soon as I hit the gas it cracks and backfires. Seems to be backfiring from the carb. I took the carb off and broke it all down. Took the jets out (170 and a 40). Cleaned everything and blew air through everything. Assembled it and still getting the backfiring, hard cracking. It will not rev out at all. I took the plugs out and they were black. Put new plugs in and still nothing. Now it will not even run without the choke on. I adjusted the pilot screw to 3 1/2 turns when I assembled the carb. I tried screwing it in and out with it running and nothing will happen, the engine stays running with it all the way in or out. I took the gas cap off to see if it wasn't getting air and nothing. Took the airbox cover off, nothing. I am supposed to be going riding Friday for a few days and would like to get this running right. Any help would be appreciated.
Old Jul 17, 2013 | 09:53 PM
Ajkd4's Avatar
Ok. I took the carb apart again. Cleaned everything with cleaner and air. Changed the oil. Flushed the radiator. Put everything back together and now it wont start at all. I am lost. I dont know where to go next. Any idas would be appreciated. Thanks.
Old Jul 18, 2013 | 01:23 PM
O2x4's Avatar
Go to ds650.org ask again there. 2 1/2 is stock. I got a cdi, pipe, jetted, omr carb mods & i think im only at about 3 turns on screw.
Old Jul 18, 2013 | 01:30 PM
O2x4's Avatar
Carb clearners are known to swell the carb seals etc. My choke circut has been givin me problems since i carb cleaned it. Had to replace my float needle and seat after too cuz it wouldnt stop drippin
Old Jul 19, 2013 | 10:52 PM
justme23005's Avatar
Did you check to make sure you had a good supply of fuel going to the carburetor?
Old Jul 24, 2013 | 10:37 PM
O2x4's Avatar
Read the omr stock carb mods located on this forums stickeys. Sounds like your floats are out of level.
Old Sep 15, 2013 | 01:34 AM
DSDEMON's Avatar
Default battery
make sure your battery is good and the cables are tight sounds like a battery conn problem
Old Sep 15, 2013 | 07:49 AM
Diaphram on the top of the carb is probably shot..
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
