More power
Old Jul 18, 2013 | 07:51 PM
Jackal315's Avatar
Default More power
Was wondering if their is less expensive way to increase power without breaking the bank. Jet kit not too bad $$, but the exhaust is out of reach right now.
2002 Honda Foreman 450 4x4
26" perelli Mudweisers
Front disc brake conversion
Old Jul 22, 2013 | 07:36 PM
Doctorturbo's Avatar
GOT BOOST!
About the only way to make some more power is more airflow through the engine. Cam, port work, exhaust, etc. Sure you can go higher compression and pick up a few horses but that means more $$$'s for better fuel.
So no, not really.
Old Jul 23, 2013 | 07:26 AM
TLC's Avatar
TLC
The really not much you can do with the Honda OHV motors. Your just going to spend more then the what little power increase you will feel.
OHV is the reason Honda Utilities ATVs are the lowerest HP per cc .Everyone uses OHC motors their even shifting to DOHC more, even honda used OHC in their Sport ATVs or they would be running dead last.
Old Jul 23, 2013 | 08:39 AM
NAELIMITS's Avatar
From: Bonny banks of the northern scottish highlands
You could diy the head a little if your cool wi the opening of ports? that costs no money, also removing matierial around valve base(penny on a stick) to match being rejetted, but apart from that a donor engine might be the way forward, a transplant that needs a little work?
also borrowing a pipe bender and fabricate an exhaust up? done it myself and so long as you can weld??
out of ideas?
T
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
