Wanted: Any lightweight or go fast parts for DS650
Old Jul 22, 2013 | 10:06 PM
CrazyWhiteDude's Avatar
Default Wanted: Any lightweight or go fast parts for DS650
Looking for any lightweight or go fast parts for 2001 DS650 thats pretty much stock at the moment
Old Jul 24, 2013 | 01:42 AM
sprinklz's Avatar
im rebuilding the same bike, any chance you could take some good pictures of the wiring harness so i can try and get mine back on?
Old Jul 24, 2013 | 10:15 PM
Sorry, my harness is in a box at the moment
Old Jul 24, 2013 | 10:19 PM
O2x4's Avatar
2004 an up i has the lightened stuff on it. Swing arm, axel, front motor mounts n supposed to b whole engine is lighter.
Go to ds650.org become a member. Once you do you will find the ds 650 shop manual.
If u still need harness help semd me pm with ur phone# n ill send u pix
Old Jul 26, 2013 | 06:08 AM
I have the lightened swingarm so far. I wasn't aware of a lighter axle. How much does it shave off? 04' and newer axles?
Old Jul 26, 2013 | 07:43 AM
O2x4's Avatar
04 Axel is shorter so it should be a little lighter. The nut on the axel changed also so you can actually preload the bearings then unload and tighten. Ive been thinkin about running the 99-03 longer swingarm with the 04 axel.
Check out the omr stock carb mods for sum free power
Old Jul 26, 2013 | 12:14 PM
Will do the carb mods. Tell me more about the axle if you can. Was it just 04'? Or 04' and up? What length did they change it and why?
Old Jul 26, 2013 | 02:22 PM
O2x4's Avatar
04 and up. I think its a 1/2 inch each side. Then the Spindes are that much longer. To make up the difference of length. So they shaved a little steel weight and replaced with aluminum weight. Total length is the same. Thats what it sounds like to me. This is from little bits of conversation i read in forums. Ds650.org & nomerceyracing. Those guys kno for sure. Ds650.org has factory change list they compiled also. Guys on those sites do alot more swapping& selling of ds stuff. Theres dura blue axels on ebay. I wanna swap my chain n sprocks for a 520 set
Old Jul 29, 2013 | 06:41 PM
ben362's Avatar
I have several items for sale, Dura blue axle, ASR upper A-arms, Two stock carbs and all jets needed to do OMR mods. Also a full set of ITP Sand Stars on custom powder coated ITP wheels. Do a search in the for sale section to see pics.
-Ben
Old Aug 12, 2013 | 10:31 AM
Boomer13's Avatar
Default DS 650 Engine Parts
Web Cams,Polished Race Head With oversized valves,Shim-under retainers,ported. Redline H/Duty Clutch Springs,Assorted bored cylinders,Engine Cases and Misc Parts.
