200m engine wont start
Old Jul 23, 2013 | 03:55 PM
2veedub's Avatar
Default 200m engine wont start
I have a 1985 200s frame with a 200m motor sittin in, and it wont start.
Cleaned everything, carb, wiring, connection, air filter, ect. It makes sparks, gas going thru carb, air filter is clean. And still no sign of life.
I just disassemble de pull start flywheel. Under, the rotor connections are al worned out.. Could this be my problem?
Old Jul 23, 2013 | 06:21 PM
2veedub's Avatar
To the top
No ones?
I got very low spark too.. Cdi statot seems nice. Coil seems fine too, spark plug's new, but still low spark
don't know how to test everything...
Old Jul 24, 2013 | 02:19 PM
Klogan121's Avatar
Damn! I'm having the same exact problem with my boy's 1984 200s!
Any help would be appreciated!
Old Jul 24, 2013 | 02:43 PM
Don't claim by any means to be a Honda guy other than the one I own,but we have worked on a few old 3 and 4 wheeler Hondas at the shop. Just curious have ya'll checked the valves,seems like the old ones were around .003 clearance (may be right,may be wrong) plus learned this from an older tech than me that had worked at a Honda dealership. He took a cdi from an old ATC200 and dropped it on the ground and hooked it back up and had spark and it ran for awhile.Of course the cdi was faulty and he ordered a new one,but he found the problem. Kinda shocked me at the time. And he did the same on an old TRX 200 with the same results. You might give it try for grins and giggles as it might work? If so,plenty of cdis on Ebay.
Old Jul 24, 2013 | 11:13 PM
2veedub's Avatar
Thinks cdi module are not testable.. Local shop guy told me this today.
Manual shop gives us some values to check out from the cdi, but they are ridiculous. So i think theres no way to test em
Is there a way to bypass the thing?
BTW thanks for all reply.. Im clueless in terms of 4strokes mecanism.
Old Jul 25, 2013 | 08:13 AM
Most cdis don't have specs to test. The manuals all say "replace with a known good one when testing ignition problems" which may work well at a dealership that have em laying around,but not for the average Joe. No way to bypass this as the cdi replaces the old points and condenser syatem and sends the spark directly to the coil and its also controls the timing advance also. Cdi's are fairly cheap on Ebay for these old machines,about the same price of a Clymer manual which I'd buy first to be able to check out the stator,etc before I started dumping parts into it that may not be the problem. Plus a manual can help you on future repairs..
Old Aug 29, 2013 | 09:25 AM
2veedub's Avatar
ok. get the thing to run. problem was the main igniter unit in the magneto.
now, Ive changed the rings and gasket and its amazing how it runs well.
BUT
seems like it dont fires a the right place, cause it backfires in the muffler every time I give him lots of gas..
dont know if you guys now what could cause that..
and when it is idling, as soon as step on the throttle theres like a little time where it want to die and then it runs well...
tried adjustin throttle cable but theres nothing to do..
Old Aug 30, 2013 | 09:21 AM
2veedub's Avatar
no one? 200s content...
Old Sep 5, 2013 | 11:46 AM
2veedub's Avatar
problem solved; vent of my gas tank cap was clogged :s
MikeyBoyesq
Nov 27, 2020 02:44 PM
tiresharkdbb
Sep 3, 2017 02:06 AM
alix
Jun 28, 2015 03:28 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
1000gade
May 27, 2015 12:37 PM
