2005 kodiak diff lock override
The reason diff lock can only be engaged while in low range or has a rev limiter is because with both front wheels locked the the ATV is very hard to steer.
Diff lock is usually just used for a short bad situation or section of trail where regular 4wd (3x4) is just not enough and you need that extra traction.
You could kill yourself or your arms at least with diff lock on for any length of time or going any faster then 20 mph.
Even if there is a way to engage diff lock while in high range or no rev limiter it would be one miserable machine control or ride.
John Reed
Sep 9, 2015 03:46 AM
