2005 kodiak diff lock override
Old 07-24-2013, 10:05 AM
bonesk78's Avatar
Default 2005 kodiak diff lock override
I just finished a ton of work on an ole kodiak. When in 4wd diff lock mode, the rev limiter stays on. Who knows of an override fix to that problem?
Old 07-24-2013, 10:15 AM
bonesk78's Avatar
There is no limiting in reverse.
Old 07-24-2013, 12:39 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
On the newer grizzlies, the rev override button overrides the limiter while diff is locked. Gray button on left handlebar.
Old 07-24-2013, 05:46 PM
Oldbear's Avatar
On my 2005 450 kodiak its the red button on the left handle bar I believe.
Old 07-25-2013, 06:19 PM
Oldbear's Avatar
Correction to my last. I agree it is the gray button the red is off and on which I never use just the key..
Old 07-27-2013, 09:43 AM
TLC's Avatar
TLC
TLC is offline
The reason diff lock can only be engaged while in low range or has a rev limiter is because with both front wheels locked the the ATV is very hard to steer.
Diff lock is usually just used for a short bad situation or section of trail where regular 4wd (3x4) is just not enough and you need that extra traction.
You could kill yourself or your arms at least with diff lock on for any length of time or going any faster then 20 mph.
Even if there is a way to engage diff lock while in high range or no rev limiter it would be one miserable machine control or ride.
Alex G.
09-11-2017 11:38 PM
salixair
11-03-2015 08:25 AM
Roro
Ask the Editor
09-30-2015 10:58 AM
John Reed
09-09-2015 03:46 AM
Brandon400
09-05-2015 08:44 PM
Quick Reply: 2005 kodiak diff lock override
