2001 Beartracker Wont Fire After Engine Swap
Old Aug 1, 2013 | 04:24 PM
badbowtie400's Avatar
Default 2001 Beartracker Wont Fire After Engine Swap
I am working on a 2001 Beartracker 250 which the owner swapped the motor with one from a Timberwolf...Has not fired since so I replaced the stator since CDI and coil were working previously...Just will not fire at all when you use the pull rope starter....I welcome any ideas...THANKS STEVE
Old Aug 1, 2013 | 06:13 PM
Jaster94's Avatar
what's the trigger output? have you measured any coil output? is the spark plug good? is the wiring harness quick connects correct? i mean, does the wiring match or did the wiring harness get changed out also. example: red to red, red to purple stripe....so on and so forth. a mismatch is what we're trying to avoid.
Old Aug 1, 2013 | 06:19 PM
Jaster94's Avatar
you could make sure there ain't no surface rust on the magnet pick up at the stator.
Well the reason I replaced the stator is cause they cut the wires...I went back with the new stator and pick up coil that plugs into the connectors on the atv... I work on a lot of atvs but will be honest I suck with a mutimeter... I have no clue how to read one properly...It has to be simple though I would think as the atv was running before they put the motor on just smoking REALLY bad
Old Aug 1, 2013 | 06:22 PM
Jaster94's Avatar
yeah, i fumble around myself on my multimeter/ohm meter. just about everytime i use mine, i gotta read the dang instructions to figure out which level i use. except for continuity, i got that one down. i would think that you're correct on that wiring being the issue. i just don't have a manual for your quad/engine.
Old Aug 1, 2013 | 06:29 PM
Ok I sure appreciate your time to reply...I am new to the forum and trying to make a temporary living working on atvs... I have 4 now that I just cant seem to get right...@ are Chinese and only problem is running rich...The beartracker is just puzzling me cause I know for a fact it was running so I would think to rule out CDI and coil...Might be wrong...
Old Aug 2, 2013 | 05:18 PM
I did notice today my aftermarket stator I used it color coded different than original...I have a red...blue...green...and black in new stator but plugs right in...PROBLEM MAYBE???
Old Aug 2, 2013 | 06:28 PM
Jaster94's Avatar
what's the "downstream" wiring go to on the wiring harness/loom itself? can you trace them out? i'm gonna look for a beartracker wiring diagram.
Old Aug 2, 2013 | 06:35 PM
I have other plug I could splice in but just hate to cut it...I SURE STARTED TO!!!
Old Aug 2, 2013 | 06:44 PM
Jaster94's Avatar
let's wait on that drastic of a move. let me look around and try to find some kind of diagram that'll tell us what is what and what the differences are. what were the year models again?
