Brute force engine noise. Now locked up
Old Sep 5, 2013 | 10:16 PM
fastline's Avatar
Default Brute force engine noise. Now locked up
I should first mention I am actually a mechanic but I have never messed with this engine. I was brought in because it seemed rather odd.
Engine would start a low rpm and want a lot of choke for whatever reason. Engine sounds normal, if you give some throttle, it would then start a VERY obvious rattle or top end knock.
It was very strange because the noise would seem to come and go and I simply could not detect the source of the noise in the 2-3min we ran it. While at near idle and still rattling, she locked up. No doubt I will now find the problem but I am really unsure where to start. starter sounded normal so not really suspecting the start clutch. Almost like a valve was hanging up but this is a pretty aggressive clank than valve tap.
I have not heard rod knock that would come and go and if I had to explain the noise I would say the sound of a screwdriver tapping on a metal heat shield.
No smoke, low on oil. no oil light when running, not suspecting CVT clutch issues. Seems to be on front side of front cylinder.
ghost civic
Jan 15, 2020 07:43 AM
greg74
Sep 10, 2019 03:03 PM
velcro7279
Aug 24, 2015 01:15 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
