88 fourtrax 350
Old Sep 6, 2013 | 12:12 AM
TODD PEDERSEN's Avatar
Default 88 fourtrax 350
I have replaced the fuel pump and the fuel cut off relay and pump continues to run all the time when engine is running. then it overcomes the needle and seat, kills the motor and gas everywhere.what tells the relay to cut power? thanks Todd
Old Sep 6, 2013 | 06:35 AM
papa hogg scoot's Avatar
Loved
Community Favorite
The CDI pulse an signal the the fuel relay then relay to pump. I gave seen CDI bad on this leg...You will need to check the signal from cdi to see if it is stuck. you could have an wire bad on this side from cdi to relay also...but most likely bad cdi on signal side.CDI is the heart beat of this system.
Old Sep 6, 2013 | 10:58 AM
Default 88 fourtrax
not to sound to stupid but what is a cdi and where is it?
Old Sep 6, 2013 | 07:11 PM
Loved
Community Favorite
Alot of people call it the brain of ignition system...Sitting on the atv its would be in the front right side corner of atv under front fender behind inner fender, bout an 3 inch by 5 inch black box.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
ScopeZ_
Jul 28, 2015 01:44 AM
