Is a hpd plain spring better than a polaris green spring?
Old Mar 27, 2001 | 06:54 PM
sparkster's Avatar
I was just wondering. If anyone nows the difference in performance of the two, please specify.
Old Mar 28, 2001 | 12:48 AM
sparkster's Avatar
Also if you have tried one of them, but not the other, tell me about the one you have experianced.
Old Mar 28, 2001 | 01:11 AM
leel's Avatar
when I talked to Rick at RCR, he said that the HPD plain spring engages at a lower rpm than the Polaris green spring. While I have not used the green spring, some others on this list have mentioned that makes for a pretty aggressive take off, which you may not want in tight woods or situations.
Good luck,
Lorrin Lee
Old Mar 29, 2001 | 08:27 AM
MustGoFaster's Avatar
I just put a green spring in. And it does take higher RPM to get it going. I've only had it in the wood trails once. It's going to take some getting use too. When I finished putting it in, I just had to try it,(about midnight). Got on, gave it gas and the darn thing didn't want to move. Had to give it alot more gas, than I did prior to the stock spring.
As far a take off--if your on hard pack, it'll bring the front end up with ease. In sand it seems to spin alot easier, not sure I like that.
As for the plain spring, it's going to take alot more RPM than the green spring. I really don't think you would want that for tech. riding.
Looking at the spring chart, It takes about 42#'s of force to start engaging the green spring, and it takes about 75#'s to engage the plain spring. Which in tern means ALOT more RPM's.
Hope this info helps. In either case enjoy.
clsharky
Jul 13, 2015 02:07 PM
toonces
Jul 11, 2015 12:01 PM
Wnthunting
Jul 9, 2015 03:02 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mphillips
Jul 2, 2015 07:20 PM
