raptor lost oil
Old Sep 14, 2013 | 01:52 AM
Shyheem Juiceman Spears's Avatar
Default raptor lost oil
My raptor had already needed a starter clutch so I had to push start it and the other day I changed the oil and filter, when I was riding it I noticed it was dripping oil a lil bitt and it was coming out by the chain and sprocket so when I was riding home I went to gear it down and all the oil poured out the bottom of it and it didn't RUn hot or anything it wouldn't go or do anything could someone help me did this come from my starter clutch?
Old Sep 14, 2013 | 09:09 AM
Raptor450's Avatar
What kind of Raptor - 50,90,125,250,350,660,700? I would say this is a whole different issue than your starter clutch. The seal around the sprocket shaft could have started leaking and if you ran the engine low in oil it could have locked the engine up.
Old Sep 14, 2013 | 09:58 AM
Raptor 660 2002 and I took the covers off due to it needed a starter clutch and that seal was broke in one spot but the ATV isn't completely dry of oil a little just drained out
Old Sep 14, 2013 | 07:53 PM
Raptor450's Avatar
OK I still think there is 2 issues here, the starter clutch being one but that should not make the machine not "go". When you say "it won't go or do anything" - what exactly does that mean? Does the engine start up and run but the ATV won't move in gear, or will the engine run at all?
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
black_thunder
Sep 6, 2015 04:41 PM
