250x help!!!!
Old Mar 27, 2001 | 08:53 PM
rider820's Avatar
Ive gone through 2 cdi boxes in a few months and the plugs keep loosening up inside. I dont wanna buy one new cause its over $100 for a little box.. I was wondering if i can use a cdi box from a newer 300ex on my 250x? thanks
Jeff
Old Mar 28, 2001 | 01:08 AM
PaulV's Avatar
Jeff,
check your stater, I had a similar problem. I thought it was my cdi box and it turned out to be my stater.
Old Mar 28, 2001 | 04:55 PM
ModdedX's Avatar
Yes, you definately have a problem other than the box... Check all your wiring for a short and also check your stator..
As far as the plug loosening, you mean the spark plug? If it is loosening tryputting a very small dab of very weak locktight on it. Just make sure none of it goes into the cylnder... Or, your plug hole may be getting stripped and you may need to take it soem where to get fixed.
Old Mar 28, 2001 | 11:06 PM
rider820's Avatar
What i mean by the pulg loosening up is.. There are 2 sets of plugs on the box, a set of 2 plugs and another set of 4. The main power plug( black and red wires) can mover around in the box. Its like the plastic housing on the box is rounded out. Because when i move the plug a certain way in the box, the quad shuts off. but if i hold it at one certain spot the quad stays running.
big_g_squared
Jun 28, 2015 04:17 PM
rockrider
Feb 20, 2001 02:51 AM
owen350x
Jul 30, 2000 01:58 AM
99_warrior_350
Jun 26, 2000 04:50 PM
YellaTerra
Mar 30, 2000 04:38 PM
