Help on my atv need advice...
Old Oct 22, 2013 | 07:37 AM
Atvfanatic123's Avatar
Default Help on my atv need advice...
I need your guys help on how i can make a place in the front, back and sides of my quad of when i get stuck something i can grab on to to lift out of its rut or whatever its stuck in. I find on the 800 sportsman there is no where to grab to pick either the front or back end up. Im looking for some ideas on something i can bolt on somewhere that i can pick it up with. The polaris sportsman 800 is not a light bike and with no where to pick it up as well makes lifting it up to get it out is soooooo hard. Thans guys in advance.
Old Oct 22, 2013 | 11:30 AM
TLC's Avatar
TLC
I can,t lift my 650lb Sportsman ATV back end or front end a inch of the ground on a flat garage floor let alone out of a wheel rut or suctioned down in a mud spot . Even cant on my 350 Grizzly. Once a machine hits 500lbs plus the man handling part is over.
I would just get a winch and let it do the work and save your spine.
Old Oct 22, 2013 | 03:04 PM
Ya that would work if there is something to attach a winch to but in fields
And sand dunes what should I do then
Old Oct 22, 2013 | 03:12 PM
There is a sand anchor that works in the conditions you've described for an anchor point with a winch.
I'd find a friend who knows how to weld and attach what you need to the frame. I think front and back would be sufficient, personally.
Old Oct 22, 2013 | 03:19 PM
If that sand anchor's built along the same principles of my son's box anchor for his boat it ought to hold.
Old Oct 22, 2013 | 09:08 PM
DogRunner2's Avatar
Lifting a 800 Sportsman to get unstuck? Let us know how that works out. lol!
Old Oct 22, 2013 | 09:46 PM
I can lift it in my garage on a three foot box in my garage put I have to use gloves and sponges so the plastic doesn't cut up my hands
Old Oct 23, 2013 | 01:16 AM
TLC's Avatar
TLC
Awesome. I may have done it once before my chiropractor visits.
But seriously there must be anchor points device for people that get suck in the tree less parries.
Old Oct 23, 2013 | 01:38 PM
DogRunner2's Avatar
Lifting it in your garage isn't the same as out on the trail. You may be off camber,pulling against the suction mud creates,etc.
Old Oct 23, 2013 | 02:54 PM
That's a good point. I moved my previous Sportsman X2 (the heaviest quad out there that I can think of) a few times from the front. I don't see being able to do that in the mud. Winch with a ****** block pulley is the best way to go or friends with tow straps. Deep mud would mean more than one friend using tow straps.
