2001 Trx250ex wot carb sputtering
Old Oct 25, 2013 | 11:36 PM
Fwoolley's Avatar
Default 2001 Trx250ex wot carb sputtering
This bike cranks and runs great except it sputters sometimes in 3rd or 4th when WOT but has good acceleration otherwise... should I pull and clean the carb? What else may cause this, old spark plug? Thanks
Old Oct 26, 2013 | 10:26 AM
sickmojave's Avatar
first thing I would do is make sure the fuel tank vent hose is clean and not pinched.. sounds like the fuel flow may be restricted...
Old Oct 30, 2013 | 12:58 PM
Fwoolley's Avatar
Check, new hose installed but still experiencing the same symptoms.
Old Oct 30, 2013 | 01:09 PM
TLC's Avatar
TLC
Changing the plug and cleaning the carb is a good thing to do no matter what and it probably will fix your problem.
I,m on a snowmobile forum where they recommend to clean carbs every season even if the machine is going good. They have this up as a "Sticky" Disassembly and Cleaning of a Mikuni Round slide Carburetor
They do not even want to give out advice until the carb is cleaned because in most cases its the trouble.
Old Oct 30, 2013 | 01:10 PM
Fwoolley's Avatar
I figured that is it. Will clean and update. Thanks
Old Oct 30, 2013 | 04:47 PM
Fwoolley's Avatar
Ok, carb is clean and new spark plug... its still doing the same thing. I noticed it sputters a little even at idle.
Could it be my Circuit exhaust (p.o. recently repacked) or a loose wire somewhere/shorting out?
Here's a video of it sputtering while giving it gas in neutral
Old Nov 14, 2013 | 04:23 PM
SWFLMUD's Avatar
I have cleaned the carb, new filter, various hoses changed , new plug, new battery, im at the same place u are 2 local shops said same thing. After years certain areas get pitted in the jets and its just time for a new carb. So thats what I will be doing. It runs great otherwise. 00 250 recon
Old Nov 14, 2013 | 04:57 PM
TLC's Avatar
TLC
A lot cheaper just to get new jets.
Old Nov 15, 2013 | 07:04 AM
Almost all carbs can be saved unless they're completely corroded inside. http://www.ebay.com/itm/Honda-TRX-250-Recon-2000-2001-2002-Carb-Carburetor-Repair-Kit-TRX250-/400576301472?pt=Motors_ATV_Parts_Accessories&hash=item5d443549a0&vxp=mtr
Old Nov 15, 2013 | 08:21 AM
budedm's Avatar
I agree. Especially on an ATV. I only ever had 1 carb go bad on me and that was on a car that had a lot of miles on it. The butterfly holes became wallered out. It would be almost impossible to get as many miles (hours) on an ATV of any kind.
Cole Hadden
Jun 15, 2025 09:05 AM
GregM
Mar 6, 2018 06:53 AM
maxjung
Jul 14, 2015 03:10 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
