05' Polaris ATP 330
Old Oct 30, 2013 | 05:15 PM
Trapper79's Avatar
Default 05' Polaris ATP 330
Just bought a new to me machine and the electric starter didn't work, no problem im mechanical i can fix it. So far can't find it. Lights come on, instrument cluster works everything works fine except the starting sequence, it will start and run fine with coil starter. I tried testing power from battery forward and didn't get anything from the exciter wire to relay the starter solenoid when switch was turned to the starting position. Eventually found that wire was severed at the handle bars and thought that would fix. After that I took the battery wire off the solenoid and put it direct to the starter wire, not one noise. So now is where im lost, my mind says the starter is obviously bad, but the solenoid doesn't switch the power over to starter either. Any thoughts? I guess i could have multiple issues. I guess my main question is if the lights and instrument panel works fine could i still have ecm problems and if there is a so called relay switch or fuse, where the are they? Any help appreciated Thanks
Old Oct 30, 2013 | 05:30 PM
Jump the solenoid posts and see if the starter engages. If it does,possibly could be an ecm problem even though the 330 wasn't on the recall list.I've replaced several on the 330s plus the ecms main function is fan and charging,but has internal circuit breakers that can short out and cause problems..
Old Oct 30, 2013 | 06:11 PM
Trapper79's Avatar
No I get nothing, that's why I jumped straight to starter and skipped solenoid and when I did that it didn't click or anything
Old Oct 30, 2013 | 06:32 PM
You can either pull the starter to see if it's binding up on the starter bendix in the recoil housing and see if it works on a bench test with jumper cables. If it doesn't could be needing a replacement. Plus keep the ecm in mind.DB Electrical - ATP
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
