2002 sportsman 700 firing problem
Old Nov 2, 2013 | 12:20 PM
woodsmen3417's Avatar
Default 2002 sportsman 700 firing problem
I have a 2002 sportsman 700 and when turning over I have no spark but once I switch it off I have one pop to the plugs any idea what causing this ? Thanks
Old Nov 2, 2013 | 08:55 PM
Look at all the posts on ignition problems on the early 700 Sportsmans.Just do a Google search. Changes from a Ducati system to a Kokusan because of all the failures. Don't try to buy Ducati stators or coil packs on Ebay! Here's the kit # and pdf instructions. About 500 bucks for the kit,but it's complete. New stator,flywheel,cdi,coil,regulator,jumper wires and instructions.Check Cycle Parts Warehouse,Cheap Cycle Parts,etc as to the best price. http://www.google.com/url?sa=t&rct=j...,d.aWc&cad=rja
Old Nov 2, 2013 | 09:12 PM
What originally was the prob was that I had a broke flywheel magnet and it scraped the stator I didn't know if it was to bad or not I had no probs with it before until that and now once I replaced the flywheel it doesn't fire so maybe new stator would fix this ?
Old Nov 2, 2013 | 09:26 PM
Problem with that is if you look up the replacement stator it refers to the new Kokusan kit#2202602 as you can't get a Ducati stator! As I mentioned,don't buy a used one on Ebay either as they will all eventually fail. Some people had indications of this system failing,others just killed the machine and it wouldn't crank back up later. I replaced more kits than I wish to remember. Item #2 on this site.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
AtvManiac78
Jul 11, 2015 03:20 AM
gfl0224
Jun 27, 2015 06:52 PM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
generalpops
Jun 5, 2015 08:23 PM
ds-newbe
Jun 3, 2015 05:40 PM
