Painting control arms??
Old Nov 16, 2013 | 06:05 PM
WilliamBos's Avatar
Default Painting control arms??
After seeing my friends 04.5 500HO with the nice red control arms, the RZR 1000 at the sled show, and an XP 850, I want to paint my control arms red.
I priced powder coating them, it will rin close to $400 up here, so opting for paint instead. Dad has a nice Devillbiss spray gun, so it will get done right, no rattle cans.
My question is, if I knock the bushings out, will I screw them up? Going to check them out tomorrow, and see if the bushings are still tight.
If I can re-use them, do I grease them up to make getting them out easier?
Want to do all 6 control arms.
Old Nov 16, 2013 | 06:31 PM
Since it's fairly new you should be able to turn and twist the bushings out. Main thing is to loosen both 9/16" a-arm bolts at the same time until you can remove them by hand. If you take one out at a time the other may just spin in the a-arm shaft. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Nov 16, 2013 | 07:09 PM
WilliamBos's Avatar
Thanks OPT. Can I remove the lower front control arms, and leave the strut bolted in? This way, I have no worries with CV shafts dropping.
When I do the rears, can I leave the CV shafts in and just tie them up for support? or gently left them rest down on a block?
Old Nov 16, 2013 | 07:44 PM
Just remove the nut from the strut ball joint,take a blunt punch and hammer and knock the a-arm loose from the strut. Then you can remove the two bolts holding the arm to the frame and slide the arm out. The strut, drive shaft can stay as they are.
Old Nov 16, 2013 | 07:55 PM
WilliamBos's Avatar
Thanks again OPT! Now, how do I identify the control arms, left and right once off? The lowers have the holes in them for the a arm guards, but how about the uppers?
Old Nov 16, 2013 | 08:35 PM
SWFLMUD's Avatar
Ive painted a few things and used different color rope for each side to hang it. Or hung as it stands on bike Left or Right.
oh and I tied a color rope to grips designating which side
Old Nov 16, 2013 | 08:41 PM
WilliamBos's Avatar
Perfect! I may also use broom handles through them, but love your colour coding idea!
salixair
Nov 3, 2015 08:25 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
meddy0388
Sep 9, 2015 06:41 AM
Canamaniac!
Sep 4, 2015 06:44 PM
