1/4 in breather/vent tube left rear
Old Nov 19, 2013 | 04:22 PM
btminerman's Avatar
Default 1/4 in breather/vent tube left rear
So, I'm changing out the battery and this clear 1/4 inch tube running along the frame above the battery falls to the ground. I have looked for an hour and can not find where it attaches to. It had no odor (like gas).
A couple of questions - where in the heck does it go, and is it important?
Thanks!
Old Nov 19, 2013 | 04:25 PM
Depending on what model machine you have? It's probably an old vent line from the old lead acid battery or a vent line to the transmission.If the battery you now have is maintenance free,the tube isn't needed.
Old Nov 19, 2013 | 05:36 PM
btminerman's Avatar
Thanks old Polaris Tech! Sorry forgot to mention it's a '95 Polaris 400 Xplorer. My guess is it went to the transmission since it was fairly long. Is there an external vent plug on the trans that I can slide the tube onto or do I have to pop the trans cover. If the later, I'll probably leave it off.
Old Nov 19, 2013 | 05:43 PM
The gear case vent tube is right above the dip stick. Item #53. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Nov 19, 2013 | 06:23 PM
btminerman's Avatar
Thanks once again for the experienced advice. Much appreciated!
Larry
Old Dec 3, 2013 | 12:16 AM
btminerman's Avatar
After many months of rebuilding my '95 xplorer 400, and several responses from you that helped me along the way, she is up and running, and purr's like a kitten.
Yesterday, I started her to put her back on the trailer, she ran for about 45 seconds then stopped. Tried everything to start her, but wouldn't start.
After running the battery down, sitting on the deck frustrated and cussing, I realized I never turned the fuel lever to the run position and just shook my head. Some things are beyond fixing.
Thanks again for your help. You got this ol' retired guy in St. Louis thru several frustrating issues.
Larry
Old Dec 3, 2013 | 02:57 AM
Good idea though to turn the fuel off when you're through for the day on the old 2 strokes to keep them from flooding the crank case.Glad you got it running.
1986Vmax540
Jul 9, 2021 09:53 PM
STLyamwar
Jul 25, 2020 04:44 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
rcappie4
Jul 10, 2015 04:54 PM
