hay old polaris tech
Old Dec 10, 2013 | 09:19 PM
ronnierhino06's Avatar
Default hay old polaris tech
on my 95 xplorer 400 4x4 there are 3 drian plugs on the bottom of the motor, pull starter (to remove water), counter balancer (uses oil, has dip stick) and crank case, does the crank case have oil in it or is it just a drain? no crank case oil like all other 2 cycle motors.
Old Dec 11, 2013 | 05:10 AM
This is just a 10mm crank case drain screw. Only time you need to drain it is if the crank case is full of gas from a leaky carb/sitting up with the fuel valve on.
Old Dec 11, 2013 | 06:45 PM
that's what I thought, thanks
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
TheHood
Jul 26, 2015 09:51 AM
maxjung
Jul 23, 2015 08:37 PM
