Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
choke/ enricher
Old Dec 22, 2013 | 01:25 PM
pucho's Avatar
Default choke/ enricher
I was wondering if any of the experts here have a fix for a 2 stroke 50cc kasea fuel enricher bypass or can I feed it power from the stator I have a 5 wire 3wire plug/2 single wires, if this is possible what wires would I use for power? I have the ATV as bare minimum so no lights, battery, etc. Thank you in advance, don't want to get another Carb if I don't have to I have a keihin on it now.
Old Dec 23, 2013 | 04:00 AM
Electric chokes didn't work worth a flip even with a battery. Easiest way to start one is to block off the air duct tube with your thumb. This allows more fuel for quick starts as these small engines just don't have that much vacuum when cold to pull fuel mixture in.Once warm usually they'll crank right back up. Had this same problem on the first year Polaris youth models (Kasea) and same thing on the later Eton based units that followed.Manual choke conversion kits didn't help that much either. Starting problems were much better when the 4 stroke youth models came out.
Old Dec 23, 2013 | 04:09 AM
Electric chokes didn't work worth a flip even with a battery. Easiest way to start one is to block off the air duct tube with your finger. This allows more fuel for quick starts as these small engines just don't have that much vacuum when cold to pull fuel mixture in.Once warm usually they'll crank right back up. Had this same problem on the first year Polaris youth models (Kasea or Aeon built) and same thing on the later Eton based units that followed.Manual choke conversion kits didn't help that much either. Starting problems were much better when the 4 stroke youth models came out.
Old Dec 23, 2013 | 11:33 AM
pucho's Avatar
Yea I noticed that when I placed my finger over the enriched hole it started right up but the mixture between air and fuel was off, it surged in acceleration then fell, and would not accelerate when given throttle, it would just bog down. So I'm guessing a manual choke Carb is needed.
Old Dec 23, 2013 | 11:35 AM
pucho's Avatar
I have another question, is the stock jet a 75? The Carb is a nice mikuni, not keihin.
Old Dec 23, 2013 | 11:37 AM
pucho's Avatar
Do I need a bigger jet just from a air breather upgrade? I replaced the original filter .
Old Dec 23, 2013 | 03:42 PM
From what little I remember on the first little ones they were some where around 65-75 on the main jets,but being a Kasea,could be a little different.Plenty of cheap manual choke carbs on Ebay that basically fit most all the brands of small 2 strokes.http://www.ebay.com/itm/2004-2005-2006-Carburetor-POLARIS-50-PREDATOR-MANUAL-CHOKE-CARB-NEW-/200815597821?pt=Motors_ATV_Parts_Accessories&hash=item2ec18ad8fd&vxp=mtr
Old Dec 27, 2013 | 12:04 PM
pucho's Avatar
Arrow
thank you old polaris tech, i found a couple carbs on ebay but this one is the cheapest, the others had plunger/tickler style choke enrichers, but this looks like it will work just as well.
Old Dec 27, 2013 | 12:19 PM
pucho's Avatar
i also was wondering if a keihin 28mm banshee carb would work? i have a pair laying around in my shed from an old banshee
Old Dec 27, 2013 | 02:49 PM
Think you're trying to get a little too big as the stock carb size on these little 50/90 machines is about 18mm..
