03 Polaris Trailblazer
I have a Polaris Trailblazer and while mudding on it Christmas Day the thumb throttle went loose, the engine started knocking, and it died. I assumed that I fouled out a spark plug bought a replacement today and it won't fire.
I looked into the cable issue the cable will retract and pull the thumb switch back out if you pull the end of the cable by the oiler. With the carburetor cap off the the switch works properly but when replaced it won't work. Any suggestions?
If you catch some thing like this early enough you can hit the edit button and delete posts.Later on you don't have that option.
