New Polaris Ace..............
Old Jan 22, 2014 | 11:18 AM
DELUX500EFI's Avatar
BUY AMERICAN!
Question New Polaris Ace..............
Just got an e-mail from Polaris Industries..They are bringing a one seat(person) ute to the market..
It will be called ACE and looks just like a narrowed RZR...About the same size as an Sportsman..
Old Jan 22, 2014 | 11:24 AM
Just saw the video.
Old Jan 22, 2014 | 11:36 AM
scootergptx's Avatar
Supersock
Hired Gun!
First thought was the old Honda Odyssey/Pilot.
Just me, but they could add a little more to the wheelbase/width and make the seat lower. Looks like on an embankment, it's asking to roll over.
That being said, I'd like one.
Old Jan 22, 2014 | 11:54 AM
TLC's Avatar
TLC
Like the concept but not this first try.
850lbs with a 327cc motor? Even though it is DOHC with 32hp , with that low displacement it will not have the low end grunt needed for that weight.
No problem in low range on slow sections.
Why not put the new Sportsman 570 in the machine?
Sitting down with a steering wheel and only 48" wide sounds fun.
Key Features
Powerful 32 HP ProStar engine featuring dual overhead camshafts, a 4 valve cylinder head and electronic fuel injection (EFI) delivers excellent performance and fuel economy
Innovative, unique cab design offers a whole new off-road experience
Confident & Secure
On-Demand True All-Wheel Drive
Automatic transmission
Unique cab design
3-Point seatbelt
Easy attach side nets
Certified Roll Over Protection System (ROPS) cab frame
Assured stopping power with four-wheel/ four-disc braking system
Comfortable & Convenient
Bucket seat with 4" of adjustability
Easy ingress and egress with flat floor plan
Steering wheel offers 3.5" of adjustability for rider comfort
360 lb combined rack and storage capacity
1,500 lb towing capacity and high / low range transmission
Powerful 50 watt halogen lighting with high and low beams
Front rack opens to 2.8 gallons of semi-dry storage
Convenient access panel in cargo area opens to engine compartment for easy maintenance
Integrated foot rest
Easy To Ride
Independent dual a-arm rear suspension with 9.5" of suspension travel
MacPherson strut front suspension offers 8.2" of independent suspension travel
5.25 gallon fuel tank
Rider centric design
Compact & Nimble
Low-center of gravity for stable and responsive ride
10.25" ground clearance
32 HP ProStar Engine with Dual Overhead Cams and a 4 valve cylinder head
Lightweight Transmission for Efficient Power Transfer
Trail Compliant 48" Width
61.5" Wheelbase
2014 Sportsman Ace Specifications:
Engine
Engine Type: 4-Stroke DOHC Single Cylinder
Displacement: 327cc
Horsepower: 32HP
Fuel System: Electronic Fuel Injection
Cooling: Liquid
Drivetrain
Transmission/Final Drive: Automatic PVT P/R/N/L/H; Shaft
Drive System: On-Demand True AWD/2WD
Engine Braking System: N/A
Active Descent Control: N/A
Suspension
Front Suspension: MacPherson Strut With 8.2" (20.8 cm) Travel
Rear Suspension: Dual A-Arm, Anti-Sway Bar 9.5" (24 cm) Travel
Brakes
Front/Rear Brakes: 4-Wheel Hydraulic Disc with Dual-Bore Front Calipers
Parking Brake: Park in Transmission
Tires & Wheels
Front Tires: 25 x 8-12; 489
Rear Tires: 25 x 10-12; 489
Wheels: Stamped Steel
Dimensions & Capacities
Wheelbase: 61.5 inches
Dry Weight: 835 lb
Overall Vehicle Size (L x W x H): 90" x 48" x 68"
Ground Clearance: 10.25"
Seat Height: N/A
Fuel Capacity: 5.25 gallons
Front/Rear Rack or Box Capacity: 120 lb (55 kg)/240 lb (110 kg)
Payload Capacity: 575 lbs (261 kg)
Hitch Towing Rating: 1,500 lb
Hitch/Type: Standard/1.25" Receiver
Features
Cargo System: Lock & Ride
Lighting: Halogen, 55W low/ 60W high
Electronic Power Steering: N/A
Instrumentation: Digital Gauge, Analog Speedometer, Odometer, Tachometer, Tripmeter, Gear Indicator, Fuel Gauge, AWD Indicator, Hi-Temp/Low-Batt Lights, DC Outlet
Custom Package Options For Your Ultimate Riding Experience
Old Jan 22, 2014 | 12:06 PM
If Beergut is riding in it he wouldn't need an embankment to roll over.
Seriously, it's an interesting idea. I think with just the 570 in it, it isn't going to sell as well as a regular RZR. I do like the idea of a balanced machine with the driver in the center. Put the 850, 900, or 1000 in it and it will sell like crazy. Polaris certainly doesn't rest on its haunches.
Old Jan 22, 2014 | 12:22 PM
The RZR 570s that my son and a buddy's son rented in Utah to ride the Paiute Trail had good low end grunt. Their main complaint was the top end was lacking. They have the cams and transmission geared towards low to mid-range torque but not much of a top end. $7500 compared to $10,300 for the RZR 570 and $11,500 for the RZR 800 doesn't sound too bad. The more I look at it, it's an XP based 570 quad with the engine moved backwards and a lower seat height.
Old Jan 22, 2014 | 12:26 PM
TLC's Avatar
TLC
You don't want it like the Oddesy , they were way two low for rough trails they were more like a go cart.
About the motor and weight, Polaris screwed up one before on theirs short lived 335 Sportsman also the Yamaha 450 was under powered.
But 830lbs is a light RUV/UTV.
Old Jan 22, 2014 | 01:04 PM
Supersock
Hired Gun!
Maybe not as low, but they haven't done much more than change the seat and steering, then put a roll bar on a quad.
Has much bigger tires than the old Odyssey I rode. That would give it a few more inches clearance there.
I like the concept, just not the finished results. Over time, hopefully they can refine it. Rest assured, the others will have something similar soon.
Old Jan 22, 2014 | 03:07 PM
user493's Avatar
Moto Psycho
I've been wondering for years if they would ever build this. But a 327cc engine? Why not a 570 or an 800?
Old Jan 22, 2014 | 03:15 PM
Oops... I missed the 327 part. That's kind of crazy in my mind. They already have good engines in the shop. Certainly wouldn't want to drive a 327 cc up at any elevation. The 570's did okay but I wouldn't want any less.
