04 Polaris Predator 500
Old Feb 1, 2014 | 02:13 PM
Gavman9966's Avatar
Default 04 Polaris Predator 500
My quad is making a weird tick sound?
and is it bad to run it like this?
Old Feb 1, 2014 | 03:07 PM
Sounds like a loose cam chain or valve lifter noise. When's the last time you had the valves adjusted? Needs to be done same as the Outlaw I believe,manual says every 15 hrs or 6 months.15 hrs usually comes way before 6 months for most people.
Old Feb 1, 2014 | 03:11 PM
Gavman9966's Avatar
I just bought the this quad and it sat out side for a while before i got it and i just been fixing everything on it
Old Feb 1, 2014 | 03:14 PM
Gavman9966's Avatar
Also is it bad to ride it like this?
Old Feb 1, 2014 | 03:23 PM
Best to have it checked out before any thing major does happen other than what it's doing now. If it's the valves,best to let a dealer do it because of all the shims involved,plus you can always pull the valve cover and feel if the cam chain is tight yourself.http://www.cyclepartswarehouse.com/f...2004&fveh=5648
Old Feb 1, 2014 | 04:28 PM
Gavman9966's Avatar
i hate doing that they cost u a millon dollars
Old Feb 1, 2014 | 05:00 PM
Cheaper for this service(from most good dealers) if this is the problem rather than you having to buy a box of shims that cost several hundred dollars and doing it yourself. They should be able to tell real quick if this is the problem or if it's something else.
Old Feb 1, 2014 | 05:44 PM
Gavman9966's Avatar
alright man
Old Feb 1, 2014 | 05:55 PM
Gavman9966's Avatar
Where can i buy shims send me a link so i can order them, i have a friend that can do small motor work and works at a engine shop.
Old Feb 1, 2014 | 06:26 PM
Look at the link above that I posted on the parts break down and all the different sizes of shims. 30 different size shims that you have to have as you don't know what size each valve will take to bring it to with in clearance specs. Most dealers sets come with 4 each of all the sizes. You can find them on Ebay now for about 75 bucks which is usually what the dealers charge for adjusting the valves. The choice is yours whether you want to get them..
http://www.ebay.com/itm/POLARIS-500-PREDATOR-HOT-CAM-CAMS-VALVE-SHIM-KIT-/360258989969?pt=Motors_ATV_Parts_Accessories&hash=item53e11bef91&vxp=mtr
