01 trx 90 running too rich?
Old Feb 3, 2014 | 10:38 PM
kenith's Avatar
Default 01 trx 90 running too rich?
I have an 01 TRX 90 with stock bore/stroke and stock carb and jets. Its sputtering on anything past 50% throttle, until I COMPLETELY remove the air fuel screw. The farther I back out the throttle screw, the better it continues to run until it's completely removed. Revs fine with the air/fuel screw in up to 50%, problem is only on the top end power. Any ideas/help?
Old Feb 4, 2014 | 10:50 AM
Sounds like you may need a carb kit. No way you should have to remove this screw to make it run properly.Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet http://www.ebay.com/itm/Honda-TRX90-2001-2002-2003-2004-Carb-Carburetor-kit-/191059575261?pt=Motors_ATV_Parts_Accessories&hash=item2c7c09c1dd&vxp=mtr
Old Feb 4, 2014 | 11:17 AM
kenith's Avatar
Sounds like you may need a carb kit. No way you should have to remove this screw to make it run properly.Dirt Cheap Honda & Arctic Cat OEM Parts & Accessories – Cycle Parts Outlet Honda TRX90 2001 2002 2003 2004 Carb Carburetor Kit | eBay
Thanks for the links. I can get the thing running perfectly with the air/fuel screw in on the bottom and mid, just not the top. It leads me to believe its the needle, needle jet, or the main. I just wish I had a smaller main to try out.
hugemoth
Jul 20, 2020 03:28 AM
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
robj
Jun 15, 2015 08:45 PM
