hawkeye no electric start
Old Feb 15, 2014 | 03:52 PM
hawkdude's Avatar
Default hawkeye no electric start
I have an 07 hawkeye, when I go to start it with the key all it does is make a clicking noise. It pull starts fine, and for a while I could pull start it, ride around for a while turn it off, and then it would start with the key. Now it doesnt even do that. Also if I try to use the winch it will shut off as soon as the winch has a load on it. Does this sound like a battery or somthing more?
Old Feb 15, 2014 | 04:47 PM
Corey850XP's Avatar
test the voltage at the battery.
Old Feb 15, 2014 | 05:24 PM
Have the battery load tested as Corey850XP recommended,plus once it's running make sure it's charging 14-14.5 volts at the battery terminals while at a steady idle. If it's not, battery problems may be cause by a faulty regulator. Item #4.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Feb 15, 2014 | 06:02 PM
hawkdude's Avatar
I went out and the voltage before I started it up was a little over 4 volts. I started it up and at idle the volts jumped right up to 14.4 volts.
Old Feb 15, 2014 | 06:16 PM
Then just sounds like you need to take the battery and have it load tested. If battery just shows 4 volts and the charging system is good,connections are tight, then sounds like this battery has sulfated,wont hold a charge and has seen it's better days.
Old Feb 15, 2014 | 06:39 PM
hawkdude's Avatar
Ok thanks, ill give that a try!
Old Feb 19, 2014 | 11:23 PM
hawkdude's Avatar
Well I went ahead and ordered an agm battery for the hawkeye. Ive read agm batteries are the way to go. The battery in it is at least 2 years old and it a cheapo from walmart. Ill let yall know it the new battery does the trick.
Old Feb 20, 2014 | 04:22 AM
You can make the agm or any battery last even longer with a battery tender. I have a Yuasa ytx14ah that's 6 years old now.Some have gotten even more using battery tenders. When it finally dies,I can't complain.
Old Feb 20, 2014 | 08:40 AM
TLC's Avatar
TLC
You could of jumped started the ATV from a other 12v source like a car to make sure its the battery.
My 500 acted like that (Clicking) and it turned out to be a dirty sticking bush inside the starter motor needed to be cleaned and freed up.
Old Feb 20, 2014 | 10:16 AM
hawkdude's Avatar
Ok, if the battery doesnt work ill look into the starter. Thanks!
