polaris express 400 odd problem
Old Feb 25, 2014 | 08:27 PM
leonphelps's Avatar
Default polaris express 400 odd problem
hello,
have a 1996 polaris express 400 that runs fine. the problem is the plug gets wet when sitting. after sitting, I remove the plug, clean the water off, then the thing runs great. gas is fresh. I still use the oil injection system.
is this a known problem that I need to just take the plug out and get the water off of it?
it is kept in a non-heated garage and the weather has been all over the place....50-0 the past few weeks.
thanks for any help.
Old Feb 25, 2014 | 09:19 PM
Jmuddin284's Avatar
Is it water or fuel you're cleaning off of the plug? If you're getting water in the cylinder then you have a bad gasket or seal somewhere. If it's gas it could be a leaking needle/seat in the carb that is allowing fuel into the cylinder while the engine is off. It's good practice to turn the petcock to OFF when the bike isn't running. Also, do you have antifreeze in the cooling system or just water?
Old Feb 26, 2014 | 06:16 AM
leonphelps's Avatar
definitely water. does not smell like fuel and does not burn under a lighter.
I do shut the petcock off when not running.
there is antifreeze in the system. Plug does not taste sweet like anti freeze.
Old Feb 26, 2014 | 12:21 PM
Then siphon or disconnect the fuel line and fill a clear container with gas from the tank. Let it sit for awhile. If you have any water contaminated fuel you'll see the water at the bottom of the container. Plus if you have access to a radiator coolant pressure tester,this can tell for sure if you have a coolant leak from a head gasket,etc. Must hold 10psi with no drop.
Old Feb 26, 2014 | 08:03 PM
leonphelps's Avatar
already did the head pressure test today. passed with flying colors.
think I may drain the tank and go to the small engine gas to get rid of the ethanol.
Old Feb 26, 2014 | 11:26 PM
Walter iston's Avatar
most times if it will pull start with the hand recoil starter the battery could be weak. it will turn the starter motor over but not have enough power in reserve to fire the ignition system. check the battery for voltage with a volt meter .
www.carobd2shop.com
TJM
Jun 11, 2015 01:28 PM
elpayaso
Jun 3, 2015 10:39 AM
elpayaso
May 30, 2015 05:43 PM
trick33
Feb 10, 2001 08:27 PM
Burrlok
Sep 24, 2000 12:09 AM
