sunl sla50 brake engages starter
Old Mar 17, 2014 | 08:43 PM
Marine13's Avatar
Default sunl sla50 brake engages starter
2006 sunl sla50, when I press hand brake the starter engages. Any suggestions please. Gregg
Old Mar 18, 2014 | 03:02 AM
Starter button stuck, or wires to button shorted together.
Old Mar 18, 2014 | 06:05 AM
brumbear's Avatar
lol sorry that is so typical chinese quad make sure they didn't install the battery backwards
Old Mar 19, 2014 | 04:24 AM
Marine13's Avatar
Battery installed correctly. Ran fine , nothing changed, now starter engages with brake application.
Old Mar 19, 2014 | 04:27 AM
Marine13's Avatar
If starter button was stuck or shorted It would have startling issues or be stuck on or off but starter button works fine and starts atv.
Old Mar 19, 2014 | 05:44 AM
brumbear's Avatar
something is shorted in the brake switch as the starter should NOT engage until the switch is closed. If it closes and starts when you depress the brake there is an issue with the start switch circut I also would start at the switch and go backwards to the brake switch.
Old Mar 19, 2014 | 09:38 AM
Zrock's Avatar
Super Quad Patrol
The brake also has a safety in it so the unit will not start until the brake is on. So something in the start circuit is shorted or stuck like the start switch.
Old Mar 19, 2014 | 11:35 AM
Reaper9789's Avatar
If it is not turned on and you turn the key on and press the brake, does it start without pressing the starter button?
Old Mar 19, 2014 | 07:25 PM
brumbear's Avatar
Your loosing me,
1 turn key on
2 make sure kill switch is in on position
3 depress either brake front or rear
4 engage start button to start
this is the normal start up procedure.
If you have something else going on you have a problem.
what it sounds like you are saying is
1 turn key on
2 KS on
3 when you pull in or depress either brake it cranks and starts
if this is what is happening see my previous post.
Old Mar 19, 2014 | 07:30 PM
Marine13's Avatar
Yes
STLyamwar
Jul 25, 2020 04:44 AM
sweaver
11
Aug 18, 2015 03:47 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Chuck188
Jul 17, 2015 02:45 PM
ghost civic
Jul 15, 2015 10:48 PM
