Outlaw 50 no spark
Old Mar 18, 2014 | 09:27 AM
nutcracker's Avatar
Default Outlaw 50 no spark
I have an outlaw 50 my son was riding it Sunday and yeasterday it would not start or even attempt to start with the electric start or kick starting. I check and am not getting any spark at the plug. if i unhook the starter realy and jump it the start will turn the motor over just fine but still no spark. Its crazy it was running just fine the day before any help would be great.
thanks,
Chase
Old Mar 18, 2014 | 03:21 PM
nutcracker's Avatar
Fixed it the dang key switch was bad
Old Mar 18, 2014 | 03:31 PM
Wire break at a solder joint at the base of the ignition switch or what? Your finding the problem may help others that may be going through the same thing.
Old Mar 18, 2014 | 03:38 PM
nutcracker's Avatar
I took the switch apart and where the wires come thru there are 4 metals pads that when the switch is turned will close the connection and 1 was very dirty. Luckily the switch comes with 4 wires and only need 2 so i was able to pull the other 2 wires and swap the position in the connector and use the other 2 metals pads.
Chase
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
