04 600 clunky noise
Old Mar 31, 2014 | 09:08 AM
Michael Rose's Avatar
Default 04 600 clunky noise
My 600 is making a clunking noise that I'm pretty sure is in the u joints, I just can't tell which one. It makes the noise when you shift, and when you get in and out of the throttle.
Is there anything else I should look for?
I sure wish I had a stand to put this thing up on. Just by looking and pushing/pulling on the drive shafts everything seems pretty clean and tight.
Any suggestions on where to order parts would be appreciated.
Thanks
Mike.
Old Mar 31, 2014 | 10:30 AM
Just jack the rear up and have it in neutral. Rock the rear tire back and forth and check the short prop shaft u-joints going from the gear case to the rear diff. You can tell quick if this is the problem joints or if it's the prop shaft joints going from the front of the gear case to the front diff. Parts are available here. http://www.cyclepartswarehouse.com/f...ion_detail.asp All 4 ujoints have the same part number. #2202105 plus Napa part#338 listed here can interchange. Spam wordSpam wordSpam word
Plus clunking may be in the cv or plunging joints on the rear drive shafts.
Old Mar 31, 2014 | 12:40 PM
Thanks OPT, local napa has them for 13$
I will jack it up and make sure that is the problem.
Old Apr 2, 2014 | 01:44 AM
jimmypsp700's Avatar
I replaced the U-joint for my 2002 700 sp rear prop shaft (did not need to move rear diff).
BUT that clunk could be in the clutching and is somewhat typical but got better with the rubber dampened Team RR secondary.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
