2007 500 efi map sensor
Old May 7, 2014 | 11:11 AM
Ruger500efi's Avatar
Default 2007 500 efi map sensor
New to the forums hope this works
The wires on the map sensor are broken all 3. At the plug I can't find anywhere on which order they go. I think the purple wire goes in the middle other than that I am lost any help would be greatly appreciated thanks
Pink, Orange, and Purple are the colors on the wires
Old May 7, 2014 | 03:49 PM
Don't even bother as the oem connector and wiring on the map sensor are junk. Read the "sticky" in the Polaris expert section on 700/800 efi problems. Applies to the 500 also. Just order the after market harness kit from this guy. Includes the connector,wiring pigtail about 8 inches or so and shrink connectors for the wiring.I replaced toooo many Polaris harness repair kits only to have them fail again and again. Only The Best
Old May 7, 2014 | 08:21 PM
Ok thanks, I will try this fix. The unit sat for about 3 yrs, and I have had a nightmare trying to get it running. Replaced the fuel pump, engine coolant temp sensor, and still nothing. I have fuel and spark at the cyl head, but it will not run or even try to crank. Just spins over.
Jeff Roper
Feb 1, 2022 11:48 AM
Sep 23, 2015 06:23 AM
braap123
Sep 7, 2015 12:58 PM
braap123
Sep 7, 2015 10:57 AM
