confused
Old May 20, 2014 | 08:48 PM
Taurus812014's Avatar
Default confused
Ok so i got a different back brake caliper and i was bleeding the brakes and was getting pressure and then all of a sudden the top bleeder screw on the back caliper just shot out brake fluid for no reason and i no longer have any pressure. Did i blow a seal inside of it or something? Also noticed it dripping alittle under the brake caliper. Can someone please help. It may be going up for sale.
Old May 21, 2014 | 05:52 PM
Andy578's Avatar
do you loosen the bleeder screw when you were pumping the brake?
Old May 21, 2014 | 08:59 PM
Whiale pumping the hand break no i dont loosen bleeder screw. When i hold the lever down then i loosen bleeder screw
Old May 21, 2014 | 10:30 PM
Andy578's Avatar
Usually you'll want to pump with the screw loosened. make sure the fluid is full too or you'll just end up putting more air into the line.
You won't have any pressure until you tighten screw again
akguy31
Aug 31, 2019 04:34 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Pissed off
Sep 21, 2015 02:33 PM
Halffast17
Sep 11, 2015 02:30 PM
Jason Campbell
Sep 7, 2015 02:25 PM
