450 ES won't start
I had my 450 stored for the winter. This spring the battery was dead so I gave it a charge. Now it won't start. It ran great until it was stored, any recommendations? I live a LONG way from a dealer and don't have a vehicle to haul it in.
signed rookie
signed rookie
it wont turn over or it wont fire?? start by draining all the gas, change your fuel filter ( if you have one)refill we clean fresh gas, pull the plug and make sure its clean and in good shape(replace if needed)make sure the choke cable is free , check any and all electrical connections between the battery, ignition switch ( including fuses... maybe when ya charged it you popped a fuse??) , finally.. consult your manual ,it may suggest something simple that you have over looked. If all else fails loaded if up and take it to the dealer. Many times theres a simple fix to a problem such as this where it was running fine one day, then dead ( even though it sat over the winter) the next. (rodent damage to wiring anyone??)
I think every one has covered the usual suspects: Does it have SPARK, fuel, and compression???. Is kill switch in the center position? ALSO-- If you have mice in your storage area, check for a nest in your airbox, and for wiring damage caused by them chewing EVERYTHING.
Let us know how you make out. (4-MAN-S in atv time)
