Chinese sun l 110 vibration
Old Jun 20, 2014 | 09:35 PM
PrairieDog126's Avatar
Default Chinese sun l 110 vibration
Have a SunL. 110 Atv. It starts right up, idles great, and seems to be fine. When I accelerate, it makes a loud vibration noise. The tires are good and the chain is snugged up. The engine seems to be swaying back and forth even though both mounting bolts are tight. Any ideas would be appreciated
Old Jun 20, 2014 | 10:12 PM
papa hogg scoot's Avatar
Loved
Community Favorite
What type of drive system does it have???? belt? if so may check belt or clutch assy.
Old Jun 21, 2014 | 09:24 AM
Zrock's Avatar
Super Quad Patrol
if the chain is to tight it will create a vibration
Old Jun 21, 2014 | 08:46 PM
It's chain driven. I got it running after cleaning out the carb. I also tightened the chain while I was tinkering with it. I will try loosening the chain and see what happens. When it vibrates, it makes a loud noise almost like an aggressive tire would make in a truck.
Old Jun 21, 2014 | 09:41 PM
Loved
Community Favorite
Is it an auto or foot shift?
Old Jun 21, 2014 | 09:50 PM
It is auto
Old Jun 23, 2014 | 10:20 PM
I loosened the chain a bit and same problem still exists. Any other ideas?
Old Jun 28, 2014 | 10:47 AM
crankestein's Avatar
The chinese atvs tend to have vibration. The engine is bolted into the chassis without any engine mounts, direct bolt on.
Its some of the culprits of chinese atvs, my kids complain about it. Make sure you locktyte all nuts and bolts, and if possible isolate the cdi, rectifier with rubber grommets, or velcro straps.
Old Jun 29, 2014 | 09:22 AM
Zrock's Avatar
Super Quad Patrol
The sunL brand looks identical to my gio.. No vibrations at all. Only time i had vibration/noise is when i put new chain and sprockets on. Tolerances are not perfect on imports so the sprockets are a little off center. So depending on where you set your chain tightens it could be tight until it makes 1/2 a rotation or so and gets to the offset part of the sprocket then they get super tight. On mine when the chain is at its loosest section it actually hits the frame but the tightest part their is no play in the chain.
with your engine moving i would almost say that is the issue. see if your engine sway goes with the movement of the tires
Old Jul 1, 2014 | 07:09 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Ive got a 125 Jetmoto that vibrates pretty good also.. problem is like crankestein said.. the engine is only mounted with 2 bolts.. its not enough.. best fix would be to add a motor mount under the engine.
Mine is ridden by my daughter in law and she doesnt go fast enough to notice or care about it.
