avanti brigade choke issues
Old Jun 27, 2014 | 02:09 PM
bamax100's Avatar
Default avanti brigade choke issues
I have a 110 Avanti briage..been sitting a few years but I have it running great. strat easy,idles good and runs strong.only issue I am having is when I put it in 1st gear,unless I give it gas,it chokes out.
any suggestions why?
Old Jul 1, 2014 | 07:12 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Have you tried raising the idle and or turning the fuel screw out 1/2 a turn? Carb may need cleaning after sitting so long also..
Old Jul 1, 2014 | 07:17 AM
bamax100's Avatar
complete carb rebuild and is adjusted to idle perfectly and runs great
Old Jul 1, 2014 | 07:20 AM
KTM Patrol
Former Chinese POW!
Have you ever adjusted the auto clutch?
Old Jul 1, 2014 | 07:21 AM
bamax100's Avatar
no. it is a 3 speed semi automatic with reverse
Old Jul 1, 2014 | 07:25 AM
KTM Patrol
Former Chinese POW!
It could be dragging/grabbing a little and stalling the engine.. Its a easy adjustment.. there is usually a bolt/nut under a small plate on the clutch cover.. loosen the nut a turn or 2.. screw in the bolt until it hits bottom and back it off 1/2 a turn and then tighten the nut..
Old Jul 1, 2014 | 07:34 AM
bamax100's Avatar
do this while it is not running? right
this is the bolt?
Old Jul 1, 2014 | 07:45 AM
KTM Patrol
Former Chinese POW!
this is the bolt?
Yes that is it.. adjusted with the engine off..
Old Jul 1, 2014 | 07:46 AM
bamax100's Avatar
thanks.
I think it may have been tampered with because the cover was off when I got it and the guy said it needed a clutch and gave me a new one.but we have it running and it shifts fine
Old Jul 1, 2014 | 08:08 AM
KTM Patrol
Former Chinese POW!
Try adjusting it first and if that doesnt help it may need the new clutch.. Id think the adjustment should help.. have you changed the engine oil?
