Yamaha banshee will not idle correctly
Old Jul 26, 2014 | 12:14 AM
Banshee rider 99's Avatar
Default Yamaha banshee will not idle correctly
Hi everybody, I have a 1999 yamaha banshee that will not idle. It has a tors eliminator kit installed. Whenever I adjust the idle screws, it doesn't do anything. my mods are procircuit pipes, tors eliminate kit, kn air filter , and the head is shaved 25 thousandths. I have already checked all the obvious stuff and everything seems good. What could be causing this? Thanks
Old Jul 26, 2014 | 07:51 AM
A leak down test can tell if you have a gasket,case or crank seal leaking that might be causing the erratic idle.
Old Jul 26, 2014 | 11:23 PM
Thanks, but I found the problem, the head wAs warped
Old Jul 27, 2014 | 04:06 AM
Yep that would do it too. Glad you found the problem.
Cole Hadden
Jun 15, 2025 09:05 AM
ranvette
Jul 12, 2015 06:34 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
