Threads on crankshaft? Help?
Old Aug 7, 2014 | 02:45 PM
MurtherX's Avatar
Default Threads on crankshaft? Help?
A buddy of mine and I replaced the grease inside the clutch due to so much mud and dirt inside and cleaned it all up. Upon putting back together we thought we had it torqued right but apparently not, driving for about five minutes the nut came off and screwed up the ends of the thread on crankshaft.
Any ideas on how to fix this? I can't get the nut started and ordered a new nut. Here's a pic:
Old Aug 7, 2014 | 02:57 PM
Find the thread pitch and a thread file might work starting the new threads on the end. If it doesn't help then having the correct metric die to remake the threads should.
Attached Thumbnails Threads on crankshaft? Help?-correct-fit-thread-file.jpg
Old Aug 7, 2014 | 03:04 PM
MurtherX's Avatar
Sorry but new to all this thread pitch and stuff. How do I find out what the thread pitch is? All I know is the nut that came off is 22mm.
Also need to figure out the right torque specs which I will just call the dealer to find out unless someone knows.
Old Aug 7, 2014 | 03:21 PM
Simple thread pitch gauge is available with any metric/sae tap and die set or by itself. Most auto stores will have them. Shaft would either be 1.25,1.50 or 1.75 thread pitch usually. Same for the thread file,can get at most auto stores. Has several different thread pitches on all 4 sides.Plus here's an interesting video that may give you an idea on how to repair damaged threads. If in doubt on crank shaft threads,let someone repair it for you.
Old Aug 7, 2014 | 03:41 PM
MurtherX's Avatar
Thank you so much. I will check out tomorrow to see if I can find any stores. If not I have a local atv shop here in town I might just take it to them and see how much they would charge me. I feel I could do it, but I hate to ruin it and make it worst.
Old Aug 7, 2014 | 04:26 PM
That might be the smart thing to do in this case.
Old Aug 8, 2014 | 08:49 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Once repaired a couple drops of red Loctite before you torque it to spec's. Thread files work great.
Old Aug 15, 2014 | 09:25 PM
MurtherX's Avatar
Update -
Got the thread fixed, new nut and it goes on. Anyone know the proper torque specs for the 2007 Yamaha Wolverine 450? I called two yamaha dealers with two different answers
One says 72lb on primary and 72 on secondary
The other says 65 primary and 100 secondary ?
I put them on at 75 each just to test it and the machine seems to work fine. Only thing I noticed is if I rev engine up while in neutral, the belt doesn't seem to want to stop moving? So I go to shift into gear it'll kind of thud because "rpms" are techincally up. Perhaps I have grease on it? I'm going to check tomorrow.
But thanks for everything so far guys.
Old Aug 15, 2014 | 10:14 PM
3quadbob's Avatar
Thumbs up
[quote=MurtherX;3259181]Update -
That's why I joined. The helpful people here make it all worth it. Extra fill is required to post so it will log on. Have a great evening.
Old Aug 15, 2014 | 11:11 PM
MurtherX's Avatar
Forgot to add does anyone have any tips on how to torque the secondary clutch? The primary I can ratchet strap down. But the secondary I have no idea how to keep it from spinning to check torque?
ultangler
Nov 30, 2024 01:35 AM
bmxatv10
Oct 14, 2022 06:23 PM
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
