04 650 Backfired now will not run
Old Sep 20, 2014 | 05:16 PM
b.kosty's Avatar
Default 04 650 Backfired now will not run
Hey guys, Got another problem with my ATV. Before taking it apart I thought i would ask here. I have been riding this for 2 summers now, always maintaining it. I was out yesterday and while I was riding, near the end of the day, the quad backfired 2 times while accelerating in 2nd gear then stalled. It fired back up, ran fine idling but when i gave it gas, it backfired again, shut off and will now not start. When it stalled the 2nd time something sounded ruff on the inside but almost just sounded like the noise the one way starter clutch makes when it stalls, but cannot confirm, however when it stalled the 2nd time it sounded rougher then normal. When attempting to start, it sounds no different then it usually does. Sounds like kill switch is on, but is not. Guy i was riding with said it sounded like my rings went but wanted to ask here for any opinions before i go pulling my piston (with no experience). Thanks.
Old Dec 6, 2014 | 08:34 AM
05650traxtermax's Avatar
i would love to see a response to this.....i have a similar problem.....the one response i did get....thinks its a carb problem
Old Dec 6, 2014 | 08:54 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Check to make sure your carb didn't blow out of it's boot. Seen it happen many times.
Old Dec 8, 2014 | 07:45 AM
thanks for that tip....but no had a look at it and put it back....i am no carb expert but it seemed in order....amazing though that the only thing that holds it in place is a rubber hose and some clamps
Old Dec 10, 2014 | 10:26 PM
persom55's Avatar
Several things flashed through my mind while reading op's post.
1) cam timing may have jumped. Check timing chain tensioner and cam timing
2) bad cdi/stator/pickup coil. Check for spark
3) one way bearing/spragg clutch. If the machine will start by roll start then the one way bearing is bad.
Also if you don't know, ds650.org is a place dedicated to the ds650
Old Dec 11, 2014 | 11:52 AM
Thanks for the reply......i am wondering about timing to....have to research how to service and check and set that
Old Dec 11, 2014 | 11:55 AM
persom55's Avatar
There's a free service manual at Ds650.org for members, or ive got one I can link to of you want
Old Dec 12, 2014 | 07:22 AM
Just to be clear....my machine is a 05 650 traxter max xt.......and its a single cylinder. I have searched on youtube and across the net, and there does not seem to be alot of info on the single cylinder. Or maybe its my search methods. That being said, yes I would love any info you could give, yes!!! I would love a link to what you have. I have changed lots of parts over the years.....mostly CV joints, a-arms, belts....throttle....did i spell that right...lol...anyhow, thanks in advance
Old Dec 12, 2014 | 08:00 AM
persom55's Avatar
https://www.dropbox.com/sh/3wpjbggq5...cz9kGVz8a?dl=0
Ah. I just saw 04 650 in the title amd automatically thought of the ds650. but I got a manual for the traxter too
Old Dec 12, 2014 | 09:16 AM
WOW!!!! ITS CHRISTMAS!!!! What a wealth of knowledge.....some differences to mine.....but so much there I can use. I look forward to going over my bike and give it some well deserved servicing....and now that I see how much detail that is in these manuals.....I should get the one that is specific to my 05 650 traxter max xt........THANK YOU!!!!
