scrambler 500 lost its 4x4
Old Sep 14, 1999 | 12:33 AM
peewee's Avatar
our scrambler 500 lost its 4 wheel drive. the light comes on but no front wheel action.any ideas?
Old Sep 14, 1999 | 08:42 AM
whisky's Avatar
check the plugs under the nose cone there is alot of them
99 500 scrambler with hotseat pipe and clutch dg bumper soon to have pistons and air box mod 93 yamaha t-wolve with a broken taillight soon to be fixed tailight is now fixed now need to fix headlight
Old Sep 14, 1999 | 02:14 PM
Pasqualie's Avatar
Peewee, Check to see if you have any power to your hubs. If you lost both hubs, I would think that the problem is in the wiring. I do not have a wiring schematic for the new machines, but I am sure that there is a switch somwhere that is unplugged, or not working. Check the trans linkage to find these switches. It should be somewhere close. Hope that this helps.
Dave
Old Sep 14, 1999 | 07:15 PM
quad_man's Avatar
Yes, check EVERY wire under the hood and make it sure it's all hooked in. When I was messing with my speedometer, I left the ground wire loose and when it vibrated out it left me stuck in 2wd. Just hooked it back up and was off again.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
