Air pressure for 589's on a Grizz?
Old Apr 5, 2001 | 05:59 AM
dosperado's Avatar
Just wondering what kind of pressure folks are running in there 589's since it looks like they would practically stay up with sidewall strength alone and zero pressure. I have about 3.5 lbs all around on my Grizz right now and I am running 26 inchers. And those things are DAMN close to the front tie rod ends! (although not rubbing)
Even at 3.5 lbs they don't buldge out at all
Old Apr 6, 2001 | 02:27 AM
GrizRick's Avatar
I run 7-10lbs in mine. With a locked front end it keeps the steering alittle easier, plus I want equal tire diameter so I run the same amount in all four tires. They dig in and get with it alot better with higher air pressure. Low air pressure and floatation are good for sand, but it doesn't work as well in the mud and on the trails. Your right about them sitting pretty close to the tie rods, but they never rub.
Rick
Old Apr 6, 2001 | 07:26 PM
bayougrizz's Avatar
dosperado, what size tires are you running, and are they on stock rims?
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
1000gade
Sep 19, 2015 10:28 AM
toonces
Sep 5, 2015 01:14 PM
