WARRIOR RACING VALVE SPRING KIT????
Old Apr 5, 2001 | 10:17 PM
wolvsrule's Avatar
I have a 95 Wolverine and i want to buy a new cam and you have to get a new spring kit when you buy them it said. And nobody sells any spring kits for a Wolverine so I would like to get a Warrior Racing Valve Spring Kit. Will it fit on my Wolverine?
Old Apr 6, 2001 | 07:15 AM
gnx87's Avatar
IF it the same engine , then yes. Have you tried Alba action sports or powroll? they would probably have a valve spring kit for you.
Old Apr 6, 2001 | 12:30 PM
PamFalcioni's Avatar
I wouldn't recommend running a cam in the Wolverine that's big enough to require different springs.
Even a mild cam creates some problems with the Wolverine -- unless you've got a big bore kit.
By installing a cam with lots of lift (that's what makes the spring kit a requirement), the engine will have to rpm higher to create torque. This means that in certain situations (running big tires, muddy conditions, hillclimbs, etc) the enigne will rev, but the quad won't move! Very frustrating!
The Warrior springs are different than the Wolverine. Although the head design is similar, the spring rates are different.
What about running a milder camshaft?
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Divergent12
Dec 30, 2017 08:33 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Aitch
Jul 21, 2015 09:40 PM
